Webby
All this talk about torque, have you all just come back from Torquay?
teky said:you forgot to mention in you maths about air motion "drag" person sitting at the wheel = weight and many other equations
teky said:you answered your own questions m8, ill put a force 8 wind infront of you and then tell me it has no effect on your car
teky said:my post was against the rolling road as opposed to the track, the rolling road is at a stand still the track is going
teky said:ps :- please dont keep quoting me
Looks like your actual power was a little higher as that plot has simply clipped at the top of the scale. That would fall into the idiot operator category. You can work out your torque at any rpm by reading the corresponding power figure off the graph and using Torque (Nm) = Power (kW)*9549/rpm, to get rpm from road speed you need to know the gearing - owner's manual may give mph/1000rpm figures, or failing that use the gearbox ratio for the gear used, the final drive ratio and the tyre rolling circumference.GrahamC230K said:OK, no laughing here is the perhaps basic and unconventional power graph I (we) got:
130KW @ the wheels
30KW transmission losses
160KW total engine power.
Using W x 0.00136 = BHP
176.8 BHP @ the wheels
40.8 BHP transmission losses
= 217.6 r/u 218 BHP total engine power.
Now the graph shows my peak 218BHP @ just over 180 KM/h, which is about 110mph ish. Now peak power is suppossed to be at 5300 rpm, so that would correspond with 4th gear - 5300 rpm, as I can just squeeze 120mph before the rev limiter kicks in.
From there on I need help![]()
vixpy1 said:This is my profession guys, so if anyone has any questions. don't hesitate to ask.
Charlie.
vixpy1 said:Always willing to host guys.![]()
stats007 said:Hi Mark,
This is fine for direct comparisons , but you fail to mention that peak torque and peak power are not the same and more often than not appear in different parts of the rev band. It seems odd that on a dyno session you measure torque but then quote BHP when you are really just measuring peak torque.
e.g.
An SL500 has ~302BHP @ 5600rpm and 339 Lbft of torque at 2700 rpm.
Using your method you would have a figure of ~174 BHP - clearly not representative of the engines power.
Other than that, good post!
Andrew
