Pretty urgent help req.
R Phillips
Epping
E350 W212 estate
1999 E300 TD estate (w210?)
It may not sound that urgent but coming home in the rain lastnight my front wipers failed.
Luckily I was not to far from home but I need to use the car today for a longish trip and don't fancy banking on it staying dry.
Can anybody point me in the direction of an online diagram so I can see how it all goes together (I can still hear the motor running) I can move the blade across the screen with little resistance so I think it's a linkage problem.
Some information in THIS thread may help you to find the problem.
Moved to bodywork section too;)
If you would like a document on this please I need your Email address
One word of warning do keep the wiper blade off the glass by lifting forward and opening the bonnet when doing adjustments
FOund the fault.
The top ball has broken, so you are stuck till Monday, I believe they cost around £30
