W L Ow
The protruding circumference (the unworn part) of a worn brake disc always causes the brake pad warning wire contact to touch the disc activating the warning light before the brake pad is really worn out. I am tempted to use an angle grinder to grind off the protrution when replacing the brake pads. Has anybody done that before. Any advice whether this may cause wheel balancing problem or brake pad failure?
Thank you in advance
