push start button
SquabzZz
2017 GLC220 4MATIC
Hey people
I have seen on ebay genuine marches push start buttons obviously this won't work unless the car had keyless entry but where can I find if my C class coupe has that ???..
My C class has loads of extras but I'm quite sure it does not have keyless entry (saying that the car does had a little black sensor looking object on the door handle)
Thanks in advance
Antony
I think the little black sensor is infrared for remote locking and un locking not keyless entry.
Tony.
The little sensor thing on the door handle is actually an IR sensor - Try pointing your key at the door and holding down unlock/lock, and it'll open/close all of your windows (respectively). I can't directly help with the keyless-go and start button question, but a quick search turns up a few results, for example:
LINK1 (US Forum): Can we add push to start? - MBWorld.org Forums
LINK2 (This Forum): http://www.mbclub.co.uk/forums/general-discussion/90270-c63-keyless-go-2.html
Also some interesting in those threads regarding availability (or the lack-thereof) and the legality of actually having it over here (lack of compatibility with regulations). For example:
Toodeep said:
Just to clarify . . . . Keyless Go is incompatible with the deadlocks fitted in the UK for insurance (Thatcham) purposes on the C, E and E coupe.
So it seems like the answer ranges from "possible, but expensive and not easy to retrofit" to "impossible or illegal". Bit of a shame as it'd be quite nice to have the experience of push-to-start (the button that is, not the traditional method getting out and pushing it from the back to start, ha!).
HTH. ;)
Thanks guys that sounds about right haha
I will check them links out c63k thanks for that
Cars with keyless entry have a small black button on each handle to allow you to lock the car without the key
If your car has KG there'll be a small square rubber-covered button on each front door handle (next to the IR sensor) to lock the car.
It is (next to) impossible to retrofit KG.
Ye I wouldn't attempt to retrofit ..
Just looked good the start and stop buttons
