r129 500SL- indicator lights stays constantly on
PanMichael
Cheshire
500sl
Hello
Just went outside the house and noticed that my right indicators stays on with constant light.
When I took the fuse off they're gone but when fuse is back the lights turn on again.
When I got inside the car and turned the signal switch to the left,the left indicators are working as they should but right are still on.
Moving the signal switch to rigt position doesn't change the situation.Still have constant light
Any suggestions?
Have you turned the light switch past the 'OFF' position?
Yes,I've tried the light switch in all positions. Doesn't help
I've also tried with the key in ignition with all positions and no change.
It only goes off when fuse is taken out
Could be a stuck relay, due to water ingress.
