R129mine
hi
when I lock the R129 the red light no longer flashes to indicate the car is being alarmed (alarm works fine btw) , the green one works fine when unlocking the car.
I took the mirror and the alarm IR housing apart and found this tiny bulb (6mm from top to bottom and about 2 or 3mm wide) looking a bit burned out. The actual connector also does not look great but I think it is just the bulb that is gone
Any idea where you can get one of these? MB are quoting silly money to replace the entire section. All I need is a new bulb
Any ideas?
Any ideas?
