Radiator warning light HELP PLEASE
Low coolant level or overheating?
If it's showing low level and the level is ok, chances are it's the washer level that is low.
Been covered on here a few times, but the two sensors are in series and only a small resistance difference between the two. Add a few years and some furry connectors, and it often gets it wrong. Top up the washers and verify the warning goes. Then make and break the connectors a few times to clean up the contacts, and prevent heart-stopping warnings in the future.
thank you for taking the time to reply Elite_504 I really appreciate you pointing me in the right direction, both bottles levels are where they should be so will start breaking and making connections as suggested until I find the bad one, I did a search but only found that one thread so was all I had to go on, I think the MAF is my other problem but I will deal with that, I had been told it was done just before I brought it but clearly not or if it has then a duff/cheapo one was used. thanks again :thumb:
