random 3000rpm rev limiter
What are you reading the codes with? It does sound like the MAF but guesswork without codes or further inspection. Needs STAR session to prevent throwing parts at it. Check BlackC55s sticky for what to check
What code reader are you using?
Is the 3000 rev limit in all gears?
Sorry just a random thought the rev limit is when the car is moving? I know that mercs will not rev over 3000 when stationary
Mine does, infact there is a STAR test that requires the car to be revved and held at around 3500 rpm
The rev limit when not moving is 4000rpm, it wont be that. 3000rpm is the limp mode.
