Does anyone know if I can get away with using 255/35 winter tyres on the rear of my C63, as opposed to the 255/30 ones which are already on the car?
Thanks for that, very interesting, I hadn't even considered that it might affect my speedo reading. Looks like I'll have to keep to the stock tyre size then.
Palmballs recomendation is nearer to OEM in that the sidewall will be 79.5mm tall vs oem which is 76.5mm. The 255/35 you are thinking of are 89.25mm tall meaning a) the tyre will become 12.75mm closer to the wheel arch b) increase the rolling radius of the tyre c) cause the speedo to read a lower speed than is actually being travelled.Palmball, thank you very much, that was exactly the info I needed! 255/30 at the rears are a very expensive size! 255/35 are a lot cheaper so was wondering if I could use them, but I will take your advice and get 265/30 at the rear.
Thanks again!
Radius wise as I said above its not a great deal different to oem but not being a tyre and wheel expert I would ask someone who knows if the slightly increased tyre width is okay for the rim.I have 255/30 19's on my new E Coupe 350 CDi deliverey next week... (Rears) do you think the 265's you mention will fit my car as well... i've just pulled my hair out(and am nearly bald) trying to get a good priced set of 255's for my other car CLK 320 on 255/35/18's
on another note, would changing from standard tyre size invalidate warranty claims on the wheels...i heard of early CLS AMG wheels cracking... what du think?Radius wise as I said above its not a great deal different to oem but not being a tyre and wheel expert I would ask someone who knows if the slightly increased tyre width is okay for the rim.
My own personal opinion (not shared by everyone) has and will always be dont give them an excuse so I always keep my cars OEM. Having said that I cannot see how they could refject a claim if the tyre fitted is within the tolerances of the wheel design.on another note, would changing from standard tyre size invalidate warranty claims on the wheels...i heard of early CLS AMG wheels cracking... what du think?
