Rear Offside CLK Window
masterclk
Midlands
2011 Audi A6 S Line
Hi all
My rear window on my W208 CLK Cab has moved towards the drivers window from the bottom by about 2-3mm. Unfortunately this is preventing the seal in between the two windows to make the "bead" properly (I hope I am making sense here):confused:
The rear window also does not seem to have a a smooth movement with a bit of a metalic as it goes down. The metal bar does look like it has been rubbing with metal as the black paint has come off.
Near side window seems fine.
I have been advised that the runner below the rear window needs adjusting.
Is this common or have you guys or ladies out there got some advice.:o
masterclk said:
Hi all
My clk had the exact same fault on the same window. It was fixed by repalcing the rear window control module at a cost of £275 plus labour. Thankfully the warranty paid for it.
I hope that this is not the same....not got the warranty.
