Deadly Dave
My GFs 2009 SLK failed the test last year because of a rusty rear subframe. Mercedes replaced it no problems for free !
My question is, should I even trust this vehicle anymore? Anyone know of any similar issues that could also be a problem? I have a small window of time that I might get the dealership to get me out of this car and into a newer one. I’d love to have another potential issue to point out, once they respond with their findings and solution. Thanks.My GFs 2009 SLK failed the test last year because of a rusty rear subframe. Mercedes replaced it no problems for free !
Anything ever come of this?It transpires that the rust is the last of my worries, looking from the underside, there's a crack all around the subframe "arm". It looks like a weak / dodgy weld has broken... More sure if the corrosion was pre or post the break though.
Not really sure what's holding everything together right now other than hope. Waiting for Mercedes to come back to me next week.
The subframe is well beyond repair needs replacingYou say cant be welded?
Call one of large Mercedes breakers like dronsfield or prestige and they will be able to find you the right part.
It’s definitely worth taking it up with an MB dealer, under the terms of the 30-year corrosion warranty. You don’t need to take it to the dealer that supplied it, although if you have a good relationship with them already then that could be beneficial.I've seen a couple of comments on here saying Mercedes replaced free of charge as it seems to be a common fault so maybe I'll give that a go
Thanks for your help mate I'm gonna give them a ring I'll update when I have some infoIt’s definitely worth taking it up with an MB dealer, under the terms of the 30-year corrosion warranty. You don’t need to take it to the dealer that supplied it, although if you have a good relationship with them already then that could be beneficial.
There was a thread on here last year that detailed a successful claim, which seemed to have been dealt with quickly and with little fuss. Good luck, and please let us know the outcome.
Found it: Rear Subframe Cracked | Wheels, Tyres, Brakes & SuspensionThere was a thread on here last year that detailed a successful claim
There are many reasons for materials choice in engineering situations, and corrosion resistance of the base material is only one of them. Aluminium is far from a guaranteed better choice.Premium maker, why not make subframes from aluminum , They dont want the car to last long apparently
Spoke.to Mercedes customer service after failing to get through to anybody at a dealership and they said that in some cases it can be fixed under warranty but the car has to be taken to a dealership for a merc engineer to inspect itThanks for your help mate I'm gonna give them a ring I'll update when I have some info
Good to know. Who’s the dealer, by the way? Hughes?MB dealership rang later that Thursday morning to say.... that they will repair with no cost to myself!! I didn’t have to say anything!!
The dealership is Hughes in BeaconsfieldGood to know. Who’s the dealer, by the way? Hughes?
Oh, and welcome to MBClub - glad you found the info here helpful.
Why not ask an MB dealer to honour the corrosion warranty (as others have done) and get it done for free?looking at best part of a grand
