- Feb 22, 2010
- Location
- Stirling, Scotland
- E55 AMG W211, E250 Sport W212, (and some Imps)
Did you use new bolts for the sub frame into the chassis?
Yes I did along with new washers...I must admit I wondered if I needed to but decided that for the few £££`s I may aswell..I had to use new washers on the front of the subframe as the old ones were completely goosed anyway.....In fact Its new bolts and washers all round..I got new hub nuts with the bearings and Ive also a new nut on the Diff flange....Ive not Torqued the subframe bolts up yet as Im waiting for new Anti roll bar mounting brackets to arrive and they fit at the front of the Subframe so those 2 bolts will have to come out again....The rule of thumb I go with is..if a fixing needs to be torqued then a new one is needed if its removed...thats just the way I am...maybe a bit ott..but it wont harm anything...hence having a bucket full of odd nuts and bolts...Just in case...lol......the weather is great today so I will crack on at a steady pace......I cant go out until 6th July anyway..or is it the 1st August...??Did you use new bolts for the sub frame into the chassis?
Thanks Jason...been well worth the work...going to do a bit of bodywork if the weather permits and get my Wheels refurbished ...then do the front,That really does look very nice.
As soon as I got it on the Ground I Torqued them up and punched the locking tab down..Just need to sort out this Brake Issue...but its raining yet again here...Remember and lock the rear hub nuts with a hammer and chisel.
I assume it could be the ABS sensor as I didnt replace those they were working just fine
I took it out for a little run this Morning only about 2 miles keeping my ears open for any noises, When I got back the ABS light had gone off..so I switched off then back on and the faults had cleared...no idea how or why...the car had been nearly on its nose foe a good number weeks so I am wondering if that had anything to do with it...Ive checked a few times during the day and everything is fine...must be the "Fairy Dust" my Great Grandaughter sent me last night...she is only 5yrs old and said to me... Fairies Fix things Pop`s...I will ask them to send you some....I could do with a sack full for when I do the front in a few weeks time...ha haYou could try swapping sides to see if the fault transfers?
Thank you,...Im sure they get blinded by numbers...Nope..your wrong...lol....I did drop one with the rear Shocks...I ordered going by the part number...when they came they were way wrong...the rubbers/stops where just like door stops...mine where like little Doughnuts...the same as my W202...Gutted...I fitted the springs then thought..a bit of a stall here now, on that day my Grandson was visiting..observing the 2mtr rule as Im shielding...he came to help me as he is really interested in cars..so he comes to Grandads when Im doing anything..a 50 mile round trip for him....anyhow I came indoors to make a brew and curse..20 mins later the Lad comes in and tells me he has fitted the shocks...my heart sank...he thought he was doing right...but as they had been "Mounted"..in Auto Doc words I couldnt send them back..but I did find a supplier in the UK with the right ones...and cheaper...now I have a pair of shocks I dont know what do with...make a seat or something.....You think AutoDoc got it wrong with your rear brake calipers ! Some of my first post on here are about a main (AMG) MB dealer refusing to believe the rear calipers on my car were the correct ones despite it being parked outside and I had a bunch of photos on my phone of various C55's clearly showing the calipers being identical to mine....MB Computer says NO ! Thats when I pretty much gave up on MB main dealers.
Great work by the way
Stick em on the classified on here, or flea bay perhaps ?Thank you,...Im sure they get blinded by numbers...Nope..your wrong...lol....I did drop one with the rear Shocks...I ordered going by the part number...when they came they were way wrong...the rubbers/stops where just like door stops...mine where like little Doughnuts...the same as my W202...Gutted...I fitted the springs then thought..a bit of a stall here now, on that day my Grandson was visiting..observing the 2mtr rule as Im shielding...he came to help me as he is really interested in cars..so he comes to Grandads when Im doing anything..a 50 mile round trip for him....anyhow I came indoors to make a brew and curse..20 mins later the Lad comes in and tells me he has fitted the shocks...my heart sank...he thought he was doing right...but as they had been "Mounted"..in Auto Doc words I couldnt send them back..but I did find a supplier in the UK with the right ones...and cheaper...now I have a pair of shocks I dont know what do with...make a seat or something.....
Thank you very much, I doubt that the bolt issue would ever have been looked at, however if you where to only be changing the parts and not dropping the subframe that bolt can be cut out with a multi tool and an extended carbide blade...even a cheap Workzone one will do the job..but with care..when the new arm is fitted the nut is wider than the original and you can get a spanner on it if you put the bolt in the logical way round...I think I showed that in the pictures...In the next week or so I will be doing the front end to the same depth...everything off...refurbished and renewed...once that is completed I will be taking off the underside covers..exhaust and prop shaft...then treating and re spraying those areas...it will out live me thats for sure,..Ive just finished refurbing my rear wheels...they were a mess...its not to concourse standard but they look a hell of a lot better untill I send them off to the pro`s...there seems to be no end...but its what I like to do...Im Shielding and have been since 19th Feb on Docs orders so its given me something to do...I wish it would stop raining as all this is done on my drive....here are my Wheels..first ever attempt..Im fairly happy with them for now...I sorted out some plastics while I was at it...Sir, I am in awe at your ability, logical thinking, thoroughness and patience. Clear write- ups, and excellent photos. and I am thinking that your MB parts man must be head and shoulders above the norm.
I myself often wondered if MB eventually saw the light and changed the direction of `that` bolt during subframe assembly.
I look forward to - if and when you decide to have a go at the front end.
