SilverSaloon
- Mar 16, 2004
- 1994 W124 E300D Estate, 1985 R107 280SL
Hi
The only ever time i've replaced a hydraulic brake pipe is on a classic Bonair Folding Camper. On that, it didn't matter what shape the brake pipe was.... aslong as one end was at the hitch and they went to the cylinders on each wheel.....
i've read on here that if the brake lines go on the W124 estate you need to drop the subframe to route the new pipes? it could well be the self levelling pipes...?
either way, is that entirely necessary? it seems to me that you could just put new pipes in and route them around where you can get them, aslong as they were securely fixed in place....
i am sure i'm talking b0ll0X and have a feeling there must be a reason why it cant be done, but would like to know why the above couldnt be done instead of the time/labour charges associated with doing it the way Merc intended....
Derek
p.s. my brake pipes are fine (as far as i know anyway) so i dont plan or need to do this job anytime soon... i just wondered.
Derek
