Replacing Front Springs on a 210
230K
Belfast
09 E320 cdi Sport Estate, 98 E300TD Estate, 99 SL 500
Hi
After suffering 2 broken springs, each broke within 2 months of each other. I decided to purchase a spring compressor tool off Ebay from America. It was interesting that both springs broke at the same location about 2-3" from the bottom end of the coil.
Here is the broken spring.
A nice shiny new spring compressor set.
Raise the car up and remove the front wheels. I was able to do the 2nd spring without removing the wheel but maybe best to remove it if your a rookie. 2 post lift makes it handy.:D :D
Install the spring compressor from the bottom through the hole in the wishbone. Position the plates as far apart as possible you need every mm you can get to get the spring out.
View from under the wishbone. Tighten up to compress spring. Spring will eventually start to spin, use vice grips to stop it spinning.
Spring fully compressed and removed
Release tension on spring be undoing nut
New spring compared with old
New spring compressed, again try and get as muchof the spring compressed to leave installing easy. Be careful not to be too greedy as plates will snag on perch and wishbone when tension is released.
Wire brush and apply rust proofing to the spring seat in the perch. I used Waxoyl
Clean all the grime and grit from the wishbone, wire brush and rust proof.
Install spring from the bottom
Rotate spring untill seated correctly on the wishbone
Release tension be unding nut on compressor.
Thats it replace road wheels and give her the once over finally before letting her down off the ramp. I would thoroughly recommend the purchase of this tool if your changing spring. Far superior to the hook type. Both springs could easily be done in an hour. I even took one out again to Waxoyl the perch because it was that easy.
Tools required:
Spring Compressor.
19mm Socket and Ratchet
Wire Brush
Vice grips
Waxoyl
Ride height raised by 21mm but this may settle back a bit over time.
Good luck.
230K
Thanks for the thread and pics :cool:
Can this spring compressor be used for the front springs?
The rear springs on my CLK drop out once you free the wishbone and remove the bottom hinge of the shock absorber.
It was the front springs that were changed.
230K
Hi
230K
Excellent write up, I recently had a spring snap. I bought the spring from Deutche Motors for £42, It was only £27 from MB but was a 2 week wait from Germany and I needed it for my 10 day MOT re-test.,I had the garage doin my MOT fit it for £40.
Once fitted my car was 20mm higher on one side, I was convinced Deutche Motors had givin me a Elegance Spring and when i told them it was 20mm they said 20mm is the difference between a Sport spring and a Elegance spring, So they re-ordered another spring but by the time that came in(2 days) my car had dropped to the original height.
So a couple of speed bumps and they will probably settle down!;)
I have often wondered why MB do not finish off the bottom of the spring as they used to be with the last coil tapered off into the coil.
It looks as though they are just cut off a roll 5 miles long
Great post !
I speak as someone who has used the 'hook' type compressors before, this looks like a major improvement over the teeth gritting experience of using the former.
Do you have an name/ref of these?
Thanks again,
Great post !
Thanks again,
They used to be expensive to buy as I recall but maybe some cheaper ones out now. Klann tools do them among others http://www.klanntools.co.uk/Chapter1.pdf
Just recently used the same tool myself on my R129, and I second everything 230K says, they make changing the springs a safe and uneventful process.
That is the same kit I have and its great.
Be careful when the spring is fully tensioned
I would be very wary of cheap copies probably sourced from Asia which does not have a good reputation in that area at all.
You will only know how good it is when the compressed spring flies off into the distance taking your head with it.
At least the Klann is approved by the German auto trade unions for indemnity insurance purposes and is THE ORIGINAL DESIGN.
That why I use the Klann.
The spring compressor shown is really the only one to use. Those that clamp on the outside of the spring are not suitable for these springs.
230K - You omitted to mention the sacrificial zinc washers between the spring and the wishbone - was this an oversight?
Didnt know anything about these washers. There was non there. Tell me more??
230K
Didnt see any remnants of the old spacers at all. They stop the ends of the spring rotting???
Dieselman it is almost as if i copied you.:D If i had seen your post i wouldnt have bought the compressor. Glad i bought it though.
230K
