SilverSaloon
- Mar 16, 2004
- 1994 W124 E300D Estate, 1985 R107 280SL
I need to re-solder the back of the instrument cluster so was wondering since i've got the cluster out, is it simple enough to replace the speedo cable?
my speedo is shakey up to about 30mph and i've read a new cable fixes this. Common 124 problem apparenty and both my 124s do it.
A quick look at the haynes manual suggests i just unbolt it from the bottom of the car (next to the gearbox) and then tie some string to the end and pull it through? then use the string to pull the new cable back into place?
is it as easy as this?
anyone know how much the cable is?
any potential problems due to length of cable etc?
does just a new cable fix it, or is there additional parts that i'll need?
could i possibly grease/fix my existing cable?
thanks in advance!!
Derek
thanks in advance!!
Derek
