Kinky
I've recently noticed (twice only) that looking at the front of the car from a distance it seems to sit unevenly.
So tonight - I got home early (makes a change) and decided that I would measure the gap in all 4 wheel arches to see if I was imagining it, or if it really is sitting unevenly.
The results were basically as follows ...
Offside front 66mm
Nearside front 81mm
Therefore a 15mm difference between the front 2 arches.
Offside rear 73mm
Nearside rear 54mm
Therefore a 19mm difference between the rear 2 arches.
The measurements were not perfect and could easily be a few mm out.
I also measured the tyre sizes (just for reference) ... and 3 came in at 620mm and one at 615mm. Admittedly the measurements are very rough, parked on a slope, and the tyre that's 615mm looked to be a bit flat if anything.
The drive itself does not seem to be affected (not that I could compare to another MB at the same time), even with an offside front tyre that is very well worn on the outside edge.
The car is due for it's MOT in 3 weeks time, so I'll either replace the tyres then or I'll get a set of alloys.
Can I assume the suspension is up the duff in some way? Any pointers would be extremely grateful.
Many thanks in advance,
K
Offside front 66mm
Nearside front 81mm
Offside rear 73mm
Nearside rear 54mm
K
