Having trawled through this thread I am interested to see people claiming that they get more mileage out of "a tank of fuel" when they buy 98 or 99 instead of 95. Whilst it undoubtedly will have some effect, the sheer number of variables affecting MPG means that it is very difficult to decide whether it is the fuel itself that is making the difference. I used to monitor fuel consumption by brimming the tank on my C230k and over the years have had the opportunity to monitor its appetite over long 6,000 mile jaunts across Europe and Western Russia.
Let us look at just some of the factors which I believe influence your MPG.
1 Driving Style acceleration (how far into the carpet does your foot go? Kickdown?)
2 Top speeds, gears, rpm (the more it spins the more fuel it uses)
3 What direction is the wind blowing in (following or against you).
4 Lights, stereo, air conditioner, heater, fan (they all use power)
5 Are your tires pumped up properly (this makes a big difference)
6 Do you travel with the windows open (increase wind resistance)
7 How much crap do you carry around in the boot (increased weight)
8 How many passengers do you carry around (more dead weight)
9 Routes which you take (flat or loads of hills)
10 Route which you take (in town - loads of start stop lights - or not)
11 The amount of traffic on the road (less traffic, less changing speed)
My experience on long trips on my own is that fuel consumption can vary by as much as +/- 10% for no apparent reason. However, the single most influential factor on THESE trips was my top speed. In Germany, I tended to use alot more fuel than in Lithuania and Latvia where the limits are very low.
So unless, you want to give up part of your life and keep a mileage log in the car I suggest that we all quite worrying about it. I did.
Les
PS the best thing I did with my 11 year old car was to chuck 2 bottles of injector cleaner into the fuel tank. The engine feels much smoother on acceleration now but maybe just me trying to justify improving things. A mechanic once recommended it to me. One thing that the more expensive fuel does prevent is causing the fuel senders in the tank to play up and tell you that your tank is empty when you know its full.
