Rubber GPS antenna cover stub W210/W208/W202
salesac1
Reading
'00 W202 Classic Selection (or is it?)
Brand new replacement part. This is the rubber antenna cover only (as pictured) - it can only be obtained new as a kit with the rubber gasket that fits around the bottom of the aerial cover itself. I needed the gasket but not the antenna cover.
Someone out there probably needs the antenna cover but not the gasket :).
Here are a couple of relevant threads:
http://www.mbclub.co.uk/forums/classifieds-wanted/113747-w210-sat-nav-aerial.html
http://www.mbclub.co.uk/forums/electronics/123109-w210-gps-aerial-stub-gasket.html
Your local stealer will want £43 +VAT from you for the kit :eek:.
Even the cheapest kit on eBay will set you back around £24.
Price of the rubber antenna cover from me - £16 delivered. PM me if interested - thanks.
Still available as above, but you'll need to get in quick if you want it :).
Sold.
