The rear wiper switch is on the left stalk on post 2006 facelift models. The seven seats in the boot are one lift up unit - only really suitable for small children. I've driven the 270 280 and 320; they are all good to drive. As others have said the 270 is quite a bit more frugal on diesel, nothing in it between the 280 and the 320. All pre facelift had SBC braking which can cause a repair bill if the pump needs changing although I believe the cost of the pump has reduced. DPF was an option until some time in 2008 or 2009 so some earlier facelift cars have no DPF. The achilles heel of the facelift v6 is the oil cooler seals - a big repair bill because of the time to get to the seals in the bottom of the V. Rust is not the big problem that it was on the 210 but the 211 (even the facelift) has its problem areas - usually around the rear arches and the rear brake lines all the way under the car hidden by the covers under the sills - it can become a semi expensive bill to fix if both sides are gone. If you can put up with a rougher 4 pot then the e220 is worth considering; very reliable unit. If I were looking for one I would consider all engines and buy the lowest owner best maintained one, with a preference for a non DPF facelift 320.
Yes, the Elegance has a softer suspension, but NO, it does not wallow about like an ocean liner. Unless the vehicle has the full air suspension, then no, it's not adjustable. I think the only way to see if an Avantgarde has comfort suspension is to perhaps post the VIN number. Back in 2002/3, when these cars were first available comments were made about the firmness of the Avantgarde suspension, nothing was ever made about the Elegance ride apart from journalists saying it had the ride of a luxury car. You like the Avantgarde ride and to me, that is all that countsAll the info and advice is appreciated thanks gents.
Did the DPF come in on a models 2005 onwards. Can this be an issue also?
My dad's car will call it the e320cdi has self leveling rear suspension. It's an advantgarde. And the suspension is a really nice ride.
Are the Elegance even more softer than that of the advantgarde. If the car has comfort suspension will it have an option to change the suspension firmness with a button?
I
DPF came in around 2008.
280 and 320 is much smoother than 270.
SBC is great to use, but can be a pain if you need to fork out for new unit.
I would search out a car with no comand and upgrade to a modern carplay unit.
IIRC 55 plates had it - only way to be sure is to check data card. Having the DPF is a bonus in my opinion tbh.The DPF was introduced well before 2008 I'm sure
