Gav
Hadn't used car for 4 weeks & had to jump start it last Sunday. It started first time (on jump leads from Clio) so then gave it a 55 mile run with everything switched off (A/c, Comand Nav, radio, surround lighting etc)
Didn't check voltage on that Sunday as assumed doing so straight after running would read incorrectly anyway. On Tues night multimeter (across jump start terminals under bonnet) said 12.1v and this (Saturday) morning 11.98. (I always thought <12.1 meant >75% discharged).
However, turned ign key, waited for heater plug light to go out and to my surprise it started on the very first turnover !
Now just run it for 20 miles. Got back and checked volatge on same terminals under bonnet & got 14.2v - which suggests alt charging OK ? Next checked at battery in boot also 14.2v (with engine running).
With engine off both readings are 12.1v.
Does this mean battery is most likely faulty ?
