Still smoky!!
so far we have replaced the MAF, run 1000 miles with high concentration of injector cleaner additive, replaced the turbo to intercooler flexible hose as it was showing signs of a small leak, had the MB diagnostic check and all to no avail. The car did suffer from an apparently common engine mount breakage about two years ago, is there any chance that the EGR vacuum pipe is leaking,thus causing the EGR not to close a low revs/high load and leading to smoke? I am told that egr only closes a low revs/high load in response to inlet manifold vacuum. Smoke only happens a low revs under load.
