Sam Location
Twistedmind
Staffordshire
Mercedes C350e
Hi All, looks like i have no can bus communication from the internal drivers SAM
Where is this located, might have a look for corrosion or water ingress
03 E class W211:wallbash:
I think it's in the door at the top front behind wing mirror where door card has a removable panel. I might be wrong but think this is where I was told.
Not sure my door card has a removable panel ??
Will have a nose tomorrow
Well unless the pre facelift is different to my 56 facelift which I don't think it is!. Mine has a panel on both front doors where if the door was shut it's where the door card meets the dash and it's dash shaped too. Can only be accessed with door open.
Many thanks. Found the door control units behind the door flap ( I opened my eyes lol )
Looks like it's the under bonnet Sam unit. Lids not fixed 100% so I'm thinking of water or damp ingress.
Electrical nightmare at the moment. Might just take the car to Acid in Birmingham. Think this is out of my league.
Taking out the front fuse box and Sam
If I find a problem can I just straight swap it out, or will the replacement unit require programming ?
Replacement will require coding.
