Hi my sat nav appears to be faulty it shows my position in random places a long way from my actual position, I assume the problem is with the GPS signal does anybody have any idea for a fix? car is a 2006 CLS 320CDI thanks in advance
thanks I'll give it a try, will the radio need a security code or anything when i reconnect?I had this exact problem in my W211
It's cured it self after I had a dead battery.
Try disconnecting the battery over night and see if it resets itself.
Had to have a new GPS aerial fitted to mine when car was about 3 months old.
Not an easy job on later cars as the complete roof lining had to come down and I believe it was the rear housing on window (estate) was removed and had to be re-bonded by specialist window company.
Thank god it was covered by warranty.
Hi Alfie, what is the easier way to fix it please mateIt doesnt have to be that complex. There is a much much easier way to fix this.
My head unit for sat nav is in the boot but I assume it will be the same process?Remove head unit and fit one of these above instrument cluster etc - i fitted mine above the comand display after my retrofit, works perfect
GPS ANTENNA SATNAV FAKRA VW MFD 2 AUDI RNS-E MERCEDES COMAND APS SKODA SEAT OPEL | eBay
