tombstones
The head gasket is not the same problem as on earlier 124 where the oil and coolant passages run very close to each other at the rear of the engine, and a crossover path occurs and oil ends up in the coolant container.
The later 320 engines suffer from oil dribble down the offside of engine near front, so oil can drip down over the alternator.
This is mainly due to overfill of oil. A TSB was issued and the instruction was to reduce the fill by half litre. Never more than half way between min and max on dipstick - problem then (in majority of cases) goes away, and oil stops dribbling. Worked on my second hand 124 which has now done over 165,000 miles.
Apart from the normal w124 checks/problems the 2 unique aspects of the cabriolet are the hood and rollover mechanism as has been stated. In both cases give them a rigorous testing by operating them several times. i.e raise and lower the hood 2 or 3 times and do likewise with the roll over protection. This may strain the battery somewhat which is the other item you want in tip top condition for that very reason.
On the earlier M104 engine of mine I did have no problem at all with oil crossing over into the water. The problem was entirely due to an oilway that was close to the edge of the head adjacent to the manifold. Oil simply dribbled out onto the manifold and made a stench.
The replacement head gasket had been modified in these areas, and I am told that replacement headgaskets do not fail like the originals did. I fill my engine according to the dipstick marks and I have no leaks. I asked my mechaninc about the TSB but he had not heard of it. Do you have any more details?
Can't see that raising and lowering the roof should put a huge strain on the battery compared say to turning over an cold engine 4 or 5 times? You are right that under normal circs it would be preferable to keep the engine running while performing these operations but a correctly rated well charged battery should handle this task without a problem. If the factory fit battery- 100amp has been replaced with a lower rated battery or the battery is on its last legs then its another factor to take into account in assessing the car that's all.
Would the TSB apply to both the 3.0 and 3.2 M104 engines, or just the 3.2?
