milleplod
......in my lower back!!
After sorting the oil and filter, I thought I might as well do the air and cabin filters too - I picked up a Hengst cabin filter for under a fiver and Fram air filters for a tenner....can't beat a bargain!
Anyway, a quick look at a couple of YouTube videos showed me how easy the jobs were, so I set-to with enthusiasm. First thing I noticed was that the engine cover (E280CDi Sport) was more or less resting on the mounting pillars, rather than being held in place by the rubber bungs - I sorted that out easily enough by putting some silicone sealant in the worn bungs before refitting it, nice and secure now, and pops off with a bit more effort than before. I'll order some replacement bungs at some point. Cabin filter was a doddle, one of the easiest I've ever done - my previous Citroen involved contorting myself into the passenger footwell, upside down, and then dismantling half of the plastics behind the glovebox, while holding a torch in my mouth, to get at the filter.
Then, the air filters. Correct bolts located, undone....relevant clamps undone....one sensor disconnected....a pull up on each housing....they're off! Filters replaced, 5-minute job. Then comes the 'refitting is simply the reverse......' bit. At first, I thought the driver's side airbox had gone more-or-less staright back on.....but then realised that the 2 supporting pillars that push into rubber grommets weren't located properly....so, another attempt at getting them both in place.....nope.....then another....much wiggling (not much wiggle room though!) and then after about 20 minutes they're in! And my back's aching.....
On to the passenger side one...which made the first one seem a doddle tbh! It took 45 minutes of wiggling, removing, replacing, more wiggling, pushing, pulling....all the time being slightly stooped over the engine. I eventually got the 2 pillars into the grommets, but could then hardly move because of the pain in my lower back. Perhaps there's a knack that I've obviously not got! I did think about removing the forward air tubes, which would've provided a bit more wiggle room, but wasn't sure if I'd then have created another fiddly job getting them back in place!
Anyway, jobs done, a few quid saved....and I'm now hobbling around the house like a 90-year old, dosed up with painkillers and anti-inflammatories!
Pete
Pete
