- Jul 12, 2011
- Location
- Near Salisbury
- MX5 1.8 Sport, Range Rover 5.0 SC, BMW X1
Having recently replaced the alternator, water pump and a/c condenser plus an MOT pass without any problems last week I was looking forward to a few months trouble free driving in the C320.
However, over the last couple of days the idle has become a little low and unstable (no stalling), throttle response is a little dull and, occasionally, there is a hesitation on applying throttle, especially if doing so having slowed and then accelerating.
I called into my MB specialist yesterday and although busy hooked it to Star, no obvious faults and no codes logged although it was a very quick diagnostic.
He thinks it is the MAF, unfortunately he is away for two weeks so cannot see the car until then. After 140,000 miles and with these symptoms he is fairly confident that it needs a new MAF. I have found a new Bosch replacement and will fit this, I may return it if it is not the cause.
Does this diagnosis seem reasonable? Fitting it seems simple, a plug and a clip holding it to the throttle body.
Thanks as ever!
Thanks as ever!
