Space saver wheels poll?
Which "spare wheel " option do you prefer
  • Space Saver wheel/tyre
    Votes: 5 10.4%
  • Tyre Mobility System can of foam/ compressor/no spare
    Votes: 0 0.0%
  • Run Flat Tyres on all wheels/no spare
    Votes: 1 2.1%
  • Full Size Spare on budget steel rim
    Votes: 6 12.5%
  • Full size Spare on equivalent alloy wheel to rest of car wheels
    Votes: 36 75.0%
  • Total voters
    48
  • Poll closed .
grober
MB Master
Perth, Scotland
W204 ESTATE
I am thinking of starting a space saver wheel/ run flat tyres poll but I'm not sure if this has been done already.:confused: If NOT I would welcome suggestions as to the poll questions.
I think you answered that one yourself ;)
Runflats
or
Space Saver
I would vote space saver, the run flats I had on mine were awful, a lot better now I have "normal" tyres on :D
Sometimes all you get is a can of tyre-weld or something and a compressor (SLK).
Options I can think of:
1) Space Saver
2) Tyre Mobility System (can of foam, compressor) / no spare
3) Run Flat tyres on all wheels / no spare
4) Full sized spare wheel on budget steel rim
5) Full sized spare on equivalent alloy rim
I vote for (5) - it is effectively a free tyre and a spare rim if you kerb one.
Philip
How about:
What would you rather have in your boot:
1. Space saver plus all the junk that ends up in a boot
2. Just the junk on its own and runflats
3. A full size tyre and still have room for that junk
Or:
What is more attractive to the opposite sex:
1. Expensive car with silly looking space saver
2. Expensive car wallowing around on run flats trying to find a tyre depot that's open at 9.00pm on a Saturday evening
3. Expensive car on the wheels that God and his various deity chums intended it to be on
Some good ideas/comments so far. I will leave it another 12 -24 hrs and then try posting the options as a poll.
Having done 340 miles yesterday returning home from Paris - on a space saver -(max speed 50mph) I would vote for an equivalent alloy wheel in the boot to use for when you kerb one of the others.
This is the first time I've needed a space saver. It was 6 hours of hell. Bad handling and barely enough speed to outrun a caravan.
Never been so humiliated ..............:o
I went through this dilemma when building my boot ICE install, in the end i figured out a way of still keeping a 17" alloy as a spare with access to it and having all my system installed around it! 17" alooy was the max I could fit in, as a 18" one would not fit in the spare wheel well. Space savers suck, for the very reason marc777 has said.
would'nt that be an mot fail,, 4 x 18" and a 17" spare,,??
Mine passed - the space saver is about 5 inches wide, the alloy 9". I guess they are running on roughly same diameter if correct profile tyres to the larger alloy
think the width does'nt matter,, just the diameter,,
For your info my Merc was a ' Picadilly Car ', and did not come with a spare wheel at all, but the stealers changed it out allong with a wheel cage and bolts and a ' small ' steel wheel,when i picked it up.
Wouldn't have thought so - some cars come with different sized rims front and back (diameter as well as width!)
I don't think the spare is part of an MOT test anyway :)
Will
Can of tyre weld and an AA card. The mini has runflats. Dont rate them at all.
Will
No it isnt. Although I think if you have one it does have to be legal.
Spare wheels are not covered by the MOT test.
There was some cotrovesy though about manufacturers using a different wheel and tyre for the spare to the ones on the car. Not space sasvers, just smaller.
