Dieselman
Banned
- Jul 13, 2003
- Peugeot 403 Convertible
Just to show that I'm not a ford hater, I'm currently doing some restoration work on this.
A friend of mine had a Mk2 2.8 Ghia, it was a cool wafter.
I think Justin's car is very tidy, but think he should pay a bit more attention to detail regarding his mods, that camber definitely looks a bit over-cooked.
The Headlight is back in, the bonnet is back down to the original height now.[/COLOR][/SIZE][/FONT]
But i assure you that the wheel alignment is spot on with zero tyre wear [/COLOR][/SIZE][/FONT]
Seriously, I'm surprised at that, over how many miles and what is the camber setting? A measure with a ruler/tape and spirit level is all that is needed.
Regarding the bonnet mod, grilles near to the lead edge would be beneficial for exhausting heat as that is a low pressure area, whereas the rear is a high pressure area so won't allow air out and may actually force it in. in a worst case the inter-cooler could be exhausting hot air out so acting as an inter-warmer.
I did note the bonnet was now back to standard fit.
If you want a high pressure cool air intake, try to site it towards the centre of the car, the pressure is considerably higher, in addition the intake doesn't have to face forwards and will collect less dirt if it doesn't.
Use a manometer to find the high and low pressure zones to make them work for best effect.
iirc, your car is tuned and turbo'd so will need to exhaust quite a lot of heat. find out the underbonnet pressures in various locations and think about a partial undertray to assist airflow.
