Hello - do not be tempted to use vaseline,or back to black bumper stuff - they contain aliphatic solvents - although initially it will appear to relieve the problem,the solvent will attack the rubber and over tine it will crack and split severely - try any silicone based grease,polish sparingly.The rubber on my mirror squeaks like mad when it folds in - what can I squirt on it to stop the squeaking, but that won't affect the rubber???
When the mirror is folded back, get a can of either WD40 or 3-in-1 and fix the little plastic tube to the nozzle. Give the inside of the mirror a damn good spray all round the internals. Don't worry about it all dripping down the paintwork, it wont do any harm, just wipe it off.
Operate the mirror a few times, give it another few blasts and wipe off runs down bodywork.
This will stop the squeaking. Guaranteed. Repeat every couple of months and your mirrors will operate as quiet as a church mouse.
That's exactly what I have done/do with mine.
That stuff that goes that milky colour is what Andy at WrightTech who services my car puts on all the door and bonnet hinges.
I didnt realise that was the stuff you were talking about.
I will have to get him to shoot some inside the mirrors next time it goes in.
BTW....the 3-IN-1 spray does contain (according to the can) PTFE, although it doesnt go that colour.
You may find that the white residue is from Lithium Grease rather than the PTFE lubricant. I recently had a thread 'which lubricant' where we discussed the pro's and con's of PTFE against WD40. I used the dry PTFE to lubricate the boot lock mechanism and lock barrel and the Lithium grease on the roof mechanism and hinges.That stuff that goes that milky colour is what Andy at WrightTech who services my car puts on all the door and bonnet hinges.
Doesn't WD40 contain rubber-attacking solvents?
Is a silicone spray better?
I wouldn't recommend WD40 but would use a PTFE "dry lube" spray as used on mountain bike chainsets. Very good lubricating properties, won't attract dirt and won't polymerise. Available from Halfords![]()
Hi - I suffer from the same squeaking rubber surround when the mirror folds back. Could you provide a brand name for the lube you use?
