Squeeky power steering
cookci
Hi when i turn the steering wheel sometimes i get a high pitch noise which sounds like a belt slipping. Does this mean the belt needs tightening? can this be done easily on the car? or does the belt need changing?
Any suggestions? thanks
btw its a 2001 c200k
Look closely at the belt, if it is glazed on the inside then it could be skidding, look for cracks where it goes around a pulley or any loose threads on the edges, it just may need doing up a touch
can the belt be tightened easily?
Best bet is to stick a new belt on ,and i would check the tensioner damper well i was at it .
How difficult are they to change? I havent looked yet but the last car i did (celica) took about 5 minutes!!
