PobodY
In that case, you'll need the seat cleaned and sterilised...
The part that worries me is if they have damaged the Chassis
The chassis is not damaged, car's just scratched, you have to hit something hard to damage the chassis.
Hopefully the wheel and/or wishbone gave way before the chassis does.They did manage to buckle a wheel , so may have slid into a kerb , causing unknown damage .
Would be useful to get a copy of the insurance assessor's damage report if they decide to write it off ?
Does not look too bad, new light and a bit of paint, job done, could have been a lot worse.
Doesn't seem to have had a major shunt , I would be surprised if the chassis was damaged. The bootlid doesn't seem to have taken an impact so the roof should be OK. This is mine after a Renault boxvan failed to stop, no chassis damage I'm "reliably" informed.
On the limited information available that looks like cosmetic damage which makes the car eminently repairable-- at a cost obviously. Its possible that a complete insurance "new for old" repair rather than refurbish might push it into write off territory facing you with a buy back V take the money decision. Having read your posts on the whole sorry affair and sensing you are fastidious sort of person wrt your cars the big question you have to truthfully ask ask yourself is will you ever have confidence in the car again even when repaired? Difficult one I know- perhaps the detailed insurance assessor's report may help make up your mind ?
Miss How can i contact you, it is seen in our locality. I can put this on our local forum A pm would be best with a number .
Matt, if you can get it to THIS bodyshop, which is about 500 yds from MB-Poole, they did a fantastic job on my E55 when I had a bump just after I bought it.
I can email some before and after photos if you like. I wouldn't hesitate to go back should I need any further bodywork or respraying.
Wow how lucky were youDid they rebuild it??
Yes you could do, I If it is Poole accident repairs I've already spoken with them FWIW. They were talking fairly big bucks. I will email you my contact details...![]()
Thanks Matt
Wirth all due respect, I hope you are right Nick!
However the way the assessor was talking A fair amount of work is required to straighten the car out. New Door (as I don't want a bunch of filler in the car.) New Bumper Assembly,
Drill off and refit Parking sensors Parktronic kit. Pull out and profile rear offside wing. Replace the rear AMG body kit that is snapped in two, also the nearside AMG Side skirt. They were even talking about replacing the wheels!! I replied good luck, as Brabus don't supply 18 inch Split rim Alloy wheels any more, only 19Inch.That would be a very hard ride no doubt.
Replace wing mirror Scuffed and dented Door sills, oh and windscreen...Parts alone are not making this a cheap process not to mention the Labour on top of that...![]()
And there in lies the issue...is it a viable process, and the insurance assessors report will as you say, help me make an informed decision.![]()
