Hi there,
When you open either the passenger or drivers side door the passenger (LHS) electric window goes down on the motor.
The only way I can stop it happening is to push the up switch while opening the door. If you do this, the window will stop opening once you stop pushing either door.
If the window has opened automatically while opening either door then the switch will function with the ignition off to enable you to close it.
Very annoying any ideas how to fix it please? Or certainly what to check?
Many thanks,
Jon
Many thanks,
Jon
