- Jun 24, 2008
- Location
- London
- 2022 Hyundai IONIQ 5 RWD / 2016 Suzuki Vitara AWD
As others said there are many factors that determine wear rate - mileage isn't everything, it's how many times you actually apply the brakes - a short distance driven through back streets littered with speed humps will cause more brake wear than a longer motorway cruise etc.
But in addition, I would argue that brakes are like tyres: wear rate is a factor that has a trade-off with other factors. It obviously depends on how the pads' material mate with discs' material, as well as the operating temperatures.
Short service life is a feature, and not necessarily one that can be referred to as 'substandard'.
You may well argue that you had no use for the features that were (potentially) enhanced at the cost of higher wear rate (perhaps, better resistance to fade? Etc), but the implication is that perhaps we should be researching brakes' performance including wear rate, in the same way that we look at tyres, to ensure that we buy the correct product for our needs.
