What would you use to remove stubborn tar and insects from plastic? Tardis is typically recommended for tar, but I wonder if it safe to use on chrome grills and headlamps, in particular?
Point being not sure how products map across between UK and US but here I use autoglym intensive tar remover for removing tar spots. I have a can of tardis in my garage but still prefer the autoglym product as it doesn't need mixing or anything and is ready to use from the small bottle.
Autoglym also do a bug remover product but I don't have that.
Regular washing and a good protective base product helps in the longer term.
I used autoglym before, was ok but not super strong, I thought.
My key concern is using autoglym or Tardis on headlights and chrome around the grille - not sure if the headlights would appreciate that! Any experience? I cannot remove some deposits on headlights no matter what.
Have not tried WD40, any kinder to paint or plastic then the above?
His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
Most plastic lenses have a hard coating applied to them which is not resistant to petroleum-based products. I have personally ruined a screen on a Honda motorcycle by using AG Intensive Tar Remover to remove multiple tar spots picked up in France, so speak from experience.
