grober
MB Master
Think the message about using a petrol/diesel station with high turnover is a very relevant point,which equally applies to tyres and car batteries also.
Watched 5h gear yesterday on Discovery channel
Test was carried on VW Golf GTI
Fifth Gear Fuel test - YouTube
Erm yes! (I've been in fuel retail for 20years)
And nothing wrong with it provided u know it is what it is and you are happy that it may not have identical nutritional benefits to beef!
MB seem to employ many people who don't have a clue about mercs!!!
If yours is anything like the RX-8 that I had, any problem is more cr@ppy engine related. Worst car I've ever owned and I've had some rubbish.
Some say the additives are added by the tanker drivers as they load up whatever destination delivery they are headed for. So if that is true, you are a the risk of a human error whichever brand you choose.
I tend to use Morrison for fuel these days as the engine runs that bit quieter (relative as its a diesel). It might be the sludge in the fuel but it sounds better. Don't bother with MPG figures as they change so much on driving style, traffic and air temperature so just fill and go.
I'm a hateful engine geek and did quite a few tests on fuels with my 500e.
Essentially I had no performance improvement with regards to the butt dyno. I used to get a smoother hot idle from both Tesco 99 and V-Power and before that Optimax.
What I did see was a regular drop in mileage from 550 to 500km from a tank over many many tankfuls. I average pretty much bang on 21mpg when using V-Power and was pretty much exactly 10% less on Tesco 99. This was over about 5 tanks of each when I was doing the back to back testing, yes I was single at the time
Now my 110 Defender which currently has 218,000 miles on it, it is running well as i'm a diesel guy by trade and I only get minimal smoke when running into the governor or when off boost on a cold engine. I have run it on a 50/50 mix of Rapessed oil and diesel, Extreme winter fuel in the north of norway down to -36 Degrees, 5 litres of old engine oil after filtering and i've even run it with 5 litres of EP90 in the tank. This was all added to a nearly full tank of diesel. On all these mixes and once warm the engine never smoked. When I fill with Morrisons diesel though it will start smoking after just a couple of miles. Time and time again so now I never touch Morrisons diesel.
I did run a tank of BP Ultimate diesel when I first picked up the Defender which seemed to improve it but I think this was mainly down to giving it a long run at speed (Well 65mph for an old Defender counts as speed ) more than the fuel itself.
There was a post on Pistonheads a long while back and one of the guys who designs the mixing system for the fuel. He explained very well how the base fuel is the same but the amount and quality of the additives changes quite a lot between tanker fills depending on who wants it.
Personally I fill up the Merc with V-Power and the Defender with whichever branded fuel station i'm closest to.
I think getting fuel from a station that needs regular fresh deliveries is also important as it can go off quite quickly.
Dave!
Same here. I burn nearly all my used and refiltered engine oiI in my 300tdi. have been told to avoid EP90 as a fuel for some reason. I think someone who knew more than I do said that it is high in sulpher?
Unless you can prove the cheaper fuel caused this problem there is not much point to this post, otherwise it is just scare mongering.My mate has just had a difficulty with his E220 CDI. Basically it went into ' limp home' mode and a quick check with a diagnostic tool showed fault in EGR valve. A Trawl though EBay showed a replacement at £375 + VAT. Anyway, a quick removal and clean of the valve rectified the fault but the cause was suspected to be caused by running supermarket fuel.
It may be a few pence per litre cheaper but may cost more in the long run.
