Dammit
- Apr 16, 2017
I’m assuming this was a bore-scope type deal, but who knows- maybe they whip the heads off for a good look.
I’d imagine a borescope inspection - they wouldn’t be dismantling anything significant for £600I’m assuming this was a bore-scope type deal, but who knows- maybe they whip the heads off for a good look.
I suspect that you are correct.
I (as advised - thanks) found a USB port in the cubby under the arm-rest, which I plugged my phone into.
You can identify the phone as a bluetooth source and stream music to the head unit, although when I tested this it was a little sporadic, but I was in reach of my home wifi network so it might have been the phone switching between cellular and wifi. More investigation needed, but this is positive - my C55 couldn't do this.
There's a mystery port in the cubby which I don't recognise- what does this do please?
It's the Media Interface port, and there should be a set of 3 leads that connect to it.There's a mystery port in the cubby which I don't recognise- what does this do please?
With the appropriate lead(s) you can connect an iPhone to it and control playback from the head unit / steering wheel controls.
Looks like the media interface to me - if you connect your phone through the appropriate cable then you’ll be able to control your phone through COMAND. Take care when ordering to make sure it’s the correct one for your model. Sit down, they’re not cheap.This is the port:
Yup, that's the Media Interface port.This is the port:
This is the cable set: Media Interface cable set for NTG4.5 vehicles MY2013 onward (except SLK)
Note that if you want to connect an iPhone you will also need a genuine Apple 30-pin to Lightning converter. Pattern ones may, but generally don't, work.
I believe so. Easy enough to confirm by giving the chaps at COMAND Online a ring,Would this one, with a Lightning connector natively, not work?
iPhone 5/6 Media Interface cable (Straight Lightning connector)
If your car was specified with the Media Interface (which allows iPod, aux-in and USB connection on the Model Year 2009 audio units which have built in phone systems), you will have a MI connector in the glovebox or centre glovebox, into which you plug the appropriate cable set, or a different...www.commandonline.co.uk
£5.50 delivered -I'm amazed at the way this thread developed and the advice provided to Damnit. Props to all forum users!
I never had a need to post anything but i hope you enjoy your new wagon.
Regarding the cable situation. I sold a set of cables for £20 not to long ago on ebay. You can grab a set of ebay used for a decent price and as recommended will need a 30pin to lightning adapter.
The only one you need though is A0018278404 followed by 30 pin to lightning adapter if you want to connect your phone.
Not sure why the prices are so extortionate!
I appear to have a set of 3 cables in a sealed bag, part number A1668270104 if your interested in them let me knowYup, that's the Media Interface port.
OK drop me a private message with a price plus postage and we can hopefully sort something out. Looks like we are 150 miles or soapart so post would be necessary. Just to correct I've just noticed the bag has been opened but it has 3 cables with various connectors that I never usedYes, I am definitely interested in getting a set.
