Driving along one day my accelerator pedal went through the floor.
Ok so a little bit of rust has set in i thought.
Stripped it back to find a hole around 6 inches large.
Then stripped rubber gunk stuff applied at factory to find the inner arch mostly rotten...
Then found the inner wings to be rotten.
Then removed the side skirts to find the sills to be completely shot.
Then found most of the floor to also be rotten.
Then found bulkhead also needs some work.
Then found both rear arches starting to go.
All of this has been disguised and most likely caused by the THICK rubber insulation layer applied at the factory in germany. This hides any rust and also traps water.
Its so thick that unless you really go at the areas with a screwdriver, you would think it was solid... Would no doubt have gone through an MOT as no visible signs and feels quite tough to touch.
Whenever anyone asks a question about buying W123's I always tell them to be careful as they hide rust like no other... heres the proof!
So what started out being a small piece of welding is now a semi restoration.
Oh and im thinking of now removing the body kit altogether.. back to original but with my new AMG pentas!..
