I am considering investing in a (relatively) inexpensive car mostly for track day use. It won't be used much on the road, but will be required to drive to and from the track, so a track-only car isn't on the list. Also, I wanted a car that wasn't too highly powered so as to allow me to learn more about good circuit driving, lines etc without reaching supersonic speeds.
Some I am considering are:
Lotus Elise Series 1 - I have been advised that these are better than series 2 since they allow a wider spread of changes and are obviously less expensive. I have seen one for around the £16k mark which has only 7k miles. Advantage is dealer not too far from home!
Porsche Boxter - Early models around the 20k mark.
Caterham - Disadvantage is inability to drive to and from tracks in wet weather (in any comfort)
Renault Clio - not sure about this due to front wheel drive - would prefer rear wheel drive.
Some other considerations are that I am not someone who can do constant repairs myself (lack of time and ability!), so something that once set up would not require constant maintenance. Should also be cheap to run - ie shouldn't require brake pads/disks after 2 track days etc.
I was wondering what thoughts folk on this forum had about these, and perhaps any other suitable cars for track days before I narrow the list.
Any inputs welcomed....
thanks
DB1
thanks
DB1
