my car - sl320 R1290642F177672 Gearbox 722.6 Engine M112943
I have a constant rough idle whether in P, R or N with a bit of surging when aircon is on or steering wheel in motion, i get a light massage felt through my seat when stopped in traffic - i am very sick of it
work that has been done -
removed and cleaned throttle body and egr valve/pipes
breather hoses from valve covers to maf replaced
maf replaced
air filters
oil/oil filter
spark plugs
HT leads
Engine mounts front and gearbox mount
egr lines checked
no vacum lines even cracked
crank position sensor replaced
engine very clean
put a couple of fuel treatments through the fuel tank
fuel filter
No codes when plugged in to the 38pin proper star? machine
the vibration is only when the idle is between 560rpms and 1000rpms and once the accelerator is touched it smooths out completely and drives beautifully without hesitation
I am very tired of looking into the engine with the air filter cover off and watching it vibrate, then perfectly smooth when revs touch on 1000rpm
Thank you for listening to me and if you have any wisdom to offer i would greatly appreciate it
kindliest regardations,
Darragh.
maf replaced
air filters
oil/oil filter
spark plugs
HT leads
egr lines checked
engine very clean
fuel filter
Darragh.
