wilverley01329
- Mar 13, 2011
- e320 cdi
I have an E320cdi year 2000, when I take off from a stand still I get a brief thumping noise from the rear passenger side. This has been going on for some time now and is really starting to get to me as I can not find the problem. To eliminate the tyres I have swapped wheels corner to corner. I also had a problem where I was getting a bulb failure warning so I changed the brake switch which got rid of the bulb warning but had no effect on the thumping noise. Last weekend I changed the rear exhaust because the hanger had snapped off, but the noise is still there. there are no noises at all while the car is in motion it only happens when you first pull away, the harder you pull away the worse the noise is. I have the idea in the back of my mind that this may be being caused by the traction control sensor on the rear nearside side wheel but before I go a get another one and fit it does anyone have any other ideas as to what it may be? how easy is it to fit the traction control sensor if indeed there is such a thing, I can not find an exploded view of the read wheel so I can have a look, so it will mean taking everything to pieces just to find out what is in there. Any ideas anyone?
