Probably one for WIM (and some maths for NC).
Both track rod end gaiters are perished, so I'm aware I'll been to replace the ends soon. In advance of this I tought I'd check the tracking (using a peice of string) so I had a good reference when replacing them (also knowing a spreader bar is needed to do the tracking properly but I wanted to know the without spreader bar setting before and after I did the job and compare with after getting the tracking done a the end).
Anyway I got a 5mm toe in on each wheel over the 520mm between the high spots on the tyre - which translates to 0 degrees 33 minutes. Haynes manual says 0 degrees 33 minutes total - so is that the deviation on both wheels - so 1 degree 6 minutes in my case?
I'm not too worried, especially as the tyre wear is pretty even. Just interested to know how far out the measurements are. Anyone know how much difference the spreader bar normally makes to the measurement (exact amount will depend on the state of your bushes etc of course) and in which direction?
