Too much torque!!
R2D2
C350
For those of you of a mathematical bent; I have often wondered why my car is as fast as it is and why it uses fuel as it does. Let's see if anyone else can do the maths and then better still explain why!? My engine is a 1.8 kompressor M271 204046 143bhp in standard spec... you can research the torque bit!
Dyno graph below.
Right - working on it now.......
I'm confused! I thought a 1.8 kompressor M271 was a petrol engine but the dyno plot is surely of a turbocharged Diesel?
And why the slump in torque at 1800rpm?
It is a Supercharged Petrol engine...
Just realised Mark (Mark300SL) would have sorted this puzzle out in no time:(
Dyno graph below.
What road speed is the car doing at approx 2400 revs in top gear ?
Unless I am missing something glaringly obvious, then either the quoted rpm is not the flywheel rpm, or that is a plot of a turbocharged Diesel.
All I can tell you is that it is my 1.8 Kompressor on a dyno....
PS. Ignore the 1600rpm reading and base the calculations on the 3600 rpm on the graph that is more reliable(?)
According to the MB literature my engine is supposed to develop 220nm of torque between 2500-4200 revs. Max power of 143bhp is supposed to be at 5200rpm. The same engine in a c200 produces 240nm between 3000-4000 and a c230 produces 245nm between 2900-5500rpm....
And the question is 'why does my car make nearly double the torque it should?'?
No car just doubled its torque output on its own. Not ever!
My strongest suspicion is you have been given the wrong dyno plot. Nothing adds up. There is no other explanation. Phone them - now!
For what it's worth I was there when the graph was plotted and believe it to be correct. Remember it is an automatic as well and the bhp figures are just slighty up ie 149bhp instead of 143bhp...
That is definitely not a dyno chart of a petrol car, you only have to look at the torque to figure that one out.
Something not right, as previously posted OP given the wrong printout?
For the sake of argument, lets say then that you've got 300lbFt of torque at 3600rpm. That equates to over 200hp. :dk:
but it would explain how I held off a Mondeo 220 diesel and also my fuel consumption and also my long held belief that my car is quicker than it should be. The C230 kompressor M271 is the same engine.....
