guydewdney
my MEGA has gone POP.. I think..
symptoms:-
running v v v v slow - HDD making interesting searching noises. thought HDD was on its way out.
removed HDD and ran tests on it - inc hitachis own. nothing wrong with it. works fine in other PC (ok - not running the OS in the other machine - mounted as primary slave). no searching noises (bzzzzt........bzzzzt.... in 5 - 8 second intervals when in the mega machine).
re-loaded win 2K and re-service packed it.
no change.
removed HDD again, and checked with more s/w that ive used before. no errors worth talking about ( a couple of 'orphaned files' were found and fixed)
plugged hdd back in.... plugged power back in. nothing. well - the led for the power button comes on. no fans spin. power button does nothing. PC is supposed to play cds with pc off - cd drawer doesnt open, let alone play a cd.
i must be getting power - as the LED comes on. a generic fan plugged into the power lines spins. so power supply is (sort of) working.
unplugged and re plugged hdd, power cable, main processor fan, memory. thumped it.
nothing.
so - how do i work out if its mobo, processor, or power supply? The plug for the power supply is different to my other PCs (being micro ATX) - so i cant do a swap test....
help
symptoms:-
no change.
nothing.
help
