towing with c200K?
Hi Gazzdid - I have a caravan and up until recently, towed it with a 2005 C220CDI auto. The caravan weighed in at just under 1500kg fully loaded and the car pulled the caravan effortlessly and had no issues with power
Hi mate Ive spoke to MB and apart from giving me a heart attack by quoting me £2500 to fit a towbar theyve told me they also change the rear bumper and uprate the cooling fan. has yours been uprated and have you had any issues with cooling? personally I dont think its something i need to worry about but just wondered if you were towing with standard cooling?
Gazz
by the way, FYI ive been quoted £365 fully fitted for a detachable towbar with twin electrics. not bad I thought. thats not a proper wiring loom job though just a retrofit. not actually sure whether theres a proper wiring loom available for my model but im fairly sure it would cost a fortune if there is!
My personal thoughts are that you should not worry about uprating the fan. Just keep an wary eye on the temp if you're climbing a long hill in hot weather. (Fat chance)
I would highly recommend you ask about fitting a 13 pin continental socket instead of the twin. Of course you would also have to convert the caravan but a 13 pin is so much better engineered and easier to engage it would be money well spent.
thanks Druk thats what I was thinking.
good point about the 13 pin plug I'll have to have a think about converting the caravan. shouldnt be too much of a problem as I'm an electrician haha.
These chaps are worth a try: Mercedes Towbars - ScenicGroup.co.uk
If you ask a Mercedes dealer to fit a towbar in this part of the world then it's Scenic Group who will fit it...
You can buy an adaptor cable instead if that floats your boat.... A bungie makes a useful tie to support cable above road with a bit of flex for when required.
Hi Gazzdid. I've got a C200K as well, and have been trying to find a towbar for it for ages - so very interested in the quote you got! Did you follow it up, and if so, could you let me know who it was? Cheers
Yeah no probs the quote is with these http://www.jibtowbars.com
I've not followed it up yet as have other priorities but do plan on it within the next few months.
Let me know how you get on :-)
Also slieve, you might be interested in this. Type this number into eBay: 280436806794
Gazz
