Peter Michaels
2008 180 SE 1.8 Kompressor Automatic petrol
Hello
I am asking to get some clarity about the following.
After I start up the engine, I put my foot on the brake, and put the gear into drive position. When I do that, the gear goes in with a bit of a crunch.
I found that when I press the brake down twice as hard, often there is no crunch and gear selection is smoother
The same often happens when I go out of the driving position into reverse. Sometimes a crunch sometimes no crunch. But definitely less crunches when the brake is pressed hard. I checked transmission fluid and it's ok.
When driving at first the colder engine goes slightly higher before the next year kicks in, but ones the engine is warm, everything is nice and smooth.
Is this normal for some automatics ? Our should I worry about it? Before I bought the car I did ask the dealer to change the gear oil which he says he did.
I guess before I drive on in the morning it be better to have the handbrake engaged before going into gear and realeasing it after the gear is in position? Is it normal to press the brake down hard before putting into gear position?
Many thanks
Peter
Hello
Many thanks
Peter
