Can someone tell me the correct pressure for Viano w639 with 225/55/17 (front and rear), not run-flat tyres? I checked the plate at the fuel tank lid, but it only shows run-flat tyres.
I run them at 38psi. MB recommend normal 33 and fully loaded 44. Both in my experience are wrong as they give abnormal tyre wear and these tyres are not cheap. 33 will give you much increased shoulder wear and 44 crown wear, a short tyre life and a very hard ride. After experimenting I found that 38psi gives a better and more quiet ride and the best tyre life.
No run flat tyres. Came new with Goodyear Eagle and used them until this year when Goodyear replaced them. Still running them at 38psi and no problems also think that perhaps they are a bit more quiet than the Eagle.
