Vito 115cdi diff ratio change
I only have a nice exhaust at moment, 3 inch dump into a twin 21/4 exiting out the drivers side before the back wheel. I’m looking a gettimg a tune through didgeservices in France soon. These engines are the best sounding 4 cylinder diesels around
I run mine on Mobile 1 10w60w as I had a lifter noise/rattle. You notice its still sounds nice after a right thrashing now as it doesn't thin out. Not cheap stuff at £90.00 for 10 litres but it gives me piece of mind with my foot nailed to the floor.
Ever considered the 20/50 full synthetic Amsoil.
I actually run half 20/50 & half 10/50 makes it a 15/50 lol
Yes but your climate is plus 20c all year round. Bet the glow plugs have never been on as they work off water temperature sensor.I have to cycle mine twice in the winter to get it to start.
So i I need 10w or a battery off a tractor lol
Far out that’s crazy, we can get down to -5 degrees Celsius on some winter mornings but usually no lower than 0 but in the summer up 48 degree C
I would be interested to no how this turns out. As I bought the right type 3 times the 36:11 and they all made terrible noise. Got the job down to 40 minutes to get it out in the end without even taking the wheels off. Your new one 38 Crown 13 spigot should bring the revs down.
I have been chasing a "Sonic Boom" at 80mph on power for 3 years with mine, Diff swap 6 times. Changed prop bearings first then the whole prop.Complete exhaust. CAT joints,turbo clamps. Engine mounts,Gearbox mounts. Added the Harmonic balancer to the the rear diff. Gearbox oil and filter made no difference.
I noticed a 400rpm drop before when when I up sized the tyres so hopefully your new diff will do the same and be silent. Rebuilds on these diffs are limited to bearings only as nothing else is available (like worn out planet gears) very visible with the the cover off.Also the large outer driveshaft bearings move in and are not held with a brace over clamp.
Having to STAR it up and find its a rumbler would be very disappointing.So hope all goes well. Your choice of oil may play a part latter on if its hot there.
I had to use a digital lazer temp in the end to find out if the diff was anygood and not suddenly lock up at 70mph which is scary as hell believe me(like someone stamping on the hand brake!!). MB oil is very thin for better MPG and in someway gets to the parts faster for lubrication. But if the diffs done a 100k its only got 30k left. Tried loads of Oils and settled straight 140. Thick as hunny and takes 5 miles to thin down but at least its 45-55c instead of burning your hands to touch the diff 75c. Used a coke bottle with compressed air to get it in" Its thick.
Hi
Looking to swap my diff out for a different ratio. Did you have to unbolt shock and wish bone bolts, or can the diff be dropped and twisted out without moving wishbones?
Ive got a 109cdi just purchased a 36:11 diff for upgrade.
I purchased the V6 diff 2nd hand from shop here in Aussie. They are 2.92
I recently bought a 2009 Viano 2.2CDI with 150hp manual.
The revs are way to high for constant autobahn speed at 120kph.
The diff ratio is 3,27 currently and the 2,92 of the 3.0cdi would be just fine for me. But... It's of course not as easy as it seems.
Does anyone have experience with the aftermath of the swap? I mean changing the hardware is the easy part, adopting the settings for each signal potentially causing trouble is the tricky part.
I personally don't have Stardiagnose, but do know a workshop which does. But they also don't have experience with this particular task.
Any hints are greatly welcome.
Best regards,
Thomas
