Jul 5, 2013 #1 G gsc1ugs Active Member Joined Jun 18, 2013 Messages 113 Can anyone tell me what the injector seat cutting size is? 15mm or 17mm, the washer is 15mm so I would imagine 17mm? mine is vito 109 55plate ps: I believe plenty of grease is required to stop flakes going into the barrel? Last edited: Jul 5, 2013
Jul 8, 2013 #2 OP OP G gsc1ugs Active Member Joined Jun 18, 2013 Messages 113 anyone know what size cutter is to be used?
Jul 10, 2013 #3 OP OP G gsc1ugs Active Member Joined Jun 18, 2013 Messages 113 I have cutting kit and it says angled reamer for merc at 17mm can you confirm if I use the flat reamer or the angle?
