VW/Audi 5th gear modification
Adam230K
German oil burner
Hi Guys,
I'm contemplating modifying my 5th gear to make it longer on the VW, because I've read it is fairly simple to do. However I have not seen one successful write-up with pics or any info on where to get the parts using google!
My car is averaging 60mpg at 70mph on motorways most of the time but I know for a fact if I could get it to rev lower this will improve, and I spend most of my time on the motorway at present, so this mod makes sense.
Does anyone know of someone who has done this?
Easy! check out the Audi A2 forum, lots of pics, Mike (Skipton) is the co owner of the forum and will source the required parts and do the job for you.
There is lots of info on the different ratio's available too, and many members running the mod.
A2OC
Skipton is based near Manchester, but you could always have a day out while he does the job.
My Octavia had it done, a 110 VE TDI, with a Van Aken Tuning Box.
It didn't make any significant difference to the MPG achieved at high speed and also it made the car alot less responsive at lower speed i.e 50-70. I really wouldn't bother risking damage to your gearbox for the neglectable results.
If it's to make the cabin quieter I think it's worthwhile, but if it's to save money I'm not sure the sums quite stack up.
As above A2OC is a good starting place.
What's your rpm at 70mph?
Wait are you looking to do this on your polo?
It was my understanding you could only do it on the earlier Pre-PD 1.9TDi Engines with the 5 Speed Gearbox, but then my Octavia was a 2000MY. That's quite low mine was about 2,700 and 3,000 at 80.
This modification has been done to Audi A2 1.4TDI which I gather has the same engine and gearbox as the Polo.
^ And did it work, or did it make the gearing too tall for the available torque?
I've not done it to my car, it's only what I've read about A2 forum member's cars.
I think all the cars that have had this modification are also remapped. I've not read of anyone saying that the gearing is too tall afterwards.
