Hi All,
Well, today (at last) I managed to load the car up enough to trigger the SLS. I had to put around 250KG in to see it! Perhaps my trigger point is set too low - I think that it is just a matter of altering the position of the lever arm on the anti-roll bar so that it switches the hydraulics at a higher ride height.
From the Haynes manual it implies that the struts do no height/springing duty at all unless a load is in the car when they are pressurised via the accumulators. Until then all springing is done by the springs. This seems to ring true to experience. This would mean an inoperative SLS system wouldn't give itself away by a low rear ride height unless you loaded the car. I realise that this is to disagree with some other people here.
What I'm trying to figure out is the innards of the strut which I'm thinking must have two separate chambers - one for the normal damping function and one for the ride height/hydropneumatic spring function.
Here is a general diagram of the hydraulics (see also below):
The pump takes fluid from the reservoir and sends it to the control unit which then normally send it straight back to the reservoir. When the height lever is deflected (by a load in the car) then pressurised fluid is supplied into the accumulator and strut until a satisfactory pressure/volume is reached when the height lever is back to it's normal range, at which point fluid from the pump simply goes back to the reservoir. If the car is unloaded then the lever returns and allows fluid to freely move back to the reservoir thus depressurising the accumulator/strut.
The fact that the accumulator only gets occasional use is what gives it it's long service life of 100,000 - although to be honest I would imagine the service life to be measured in miles. After all when the accumulator is at low pressure the nitrogen will be at low pressure and very little nitrogen will leak across the diaphragm into the fluid - in a Citroen there is constant high pressure causing the spheres to deflate after just a few years.
Here are diagrams of some struts - the third strut is how I imagine a self levelling and shock absorbing strut is laid out (see also bottom):
http://www.mbclub.co.uk/forums/attachment.php?attachmentid=7318&stc=1&d=1183639056
The height strut is merely an extending piston.
The damping strut is a simple motion damper.
The combined strut would appear to do both.
Note that there is also a small flow restriction aperture in the hydraulics between the strut and the accumulator that damps the flow of that liquid as it moves quickly (as you go over bumps) between the strut and the nitrogen spring (accumulator). This is so that the additional pneumatic spring is damped - after all the fixed damper part of the strut is only designed to damp the coil spring.
Anyway, that's my understanding so far. It is open to correction!
Cheers,
Mark
